Engine Timing
Hi Bax,
How are you doing? I just wanted to know that will a Four Stroke Engine run , with wrong timing set on it. Sharad |
Engine Timing
Sharad,
If the camshaft in an O.S. Max four-stroke engine is installed incorrectly, we'd not expect the engine to run very well at all, if it will run. Even one tooth off will affect the timing drastically. |
Engine Timing
Dear Bax,
Thank s for answering. If you remember I had asked you about a 70 II FS OS MAX which I opened and lost the timing . No when I have fixed it back keeping the timing at 6 O' clock the engine is running . Is this timing position right. Let me know Sharad |
Engine Timing
Sharad,
On O.S. Max 4-stroke engines, the timing mark is NOT at 6:00 o'clock. It should be set so that it's aligned with the center of the pushrod tubes/cam follower when the engine is at Top Dead Center. If it's aligned at 6:00 o'clock, you'll be 1 or 2 teeth off. |
Engine Timing
Dear Bax,
Thanks once agian for you reply. In this case the engine timing set wrong by one or two teeth off from the setting , what kind of response will the engine give. Secondly, Now how should I align it with the center of the push rod. Thanks & Regards Sharad |
Engine Timing
The proper way to set the timing is in the following FAQ:
http://www.osengines.com/faq/product-faq.html#q15 |
| All times are GMT -8. The time now is 01:00 AM. |
