Quick PC help.
Quick PC help.
In the "My Documents" file, In the bottom left hand corner it says "8 objects (plus 1 hidden)" How do I veiw this hidden object? Or what does it mean?
FYI: Using Win XP.
FYI: Using Win XP.
RE: Quick PC help.
they are hidden system files that you shouldn't mess with if you don't know what they do. That one probably stores information about and how the other objects on that folder are displayed.
You can enable so they are visible like other files and folders, but you should leave them alone
RE: Quick PC help.
Ahh, I kinda had a thought that might be it. The thnig is I'm running a 5yr old dell with a 10gig hard drive and with XP and all other necessary software/programs all I have it around 4-5gigs to play with so I did want some useless junk filling up My HD.
But thanks a lot Nik!
ORIGINAL: Nik.
RE: Quick PC help.
That's exactly what it was, I deleted a random useless file I had in there and it was gone, Thanks for the help guys!
ORIGINAL: proanti1
Probably a thumbs file (thumbnail config). If you delete the file its attached to, it will also go away.
