THE LOUNGE 2
RE: THE LOUNGE 2
Can you use any receiver as long as you have the right crystal in it? Say I have a futaba remote and a hitech receiver with a 68 crystal would it work properly? Also what's the best cupon for tower if your going to spend 100 dollars?
CA
RE: THE LOUNGE 2
ORIGINAL: Ttam Says Blarg
RE: THE LOUNGE 2
RE: THE LOUNGE 2
Fiat 500 and Scania vids are up..
http://tamiyablog.com/
anybody owned or considered the Tamiya (58312) Blackfoot Extreme
RE: THE LOUNGE 2
I like it (what's not to like) except the small shocks!! If I get one, I'd put on some aftermarket shock towers and run 4" shocks all around!!
ORIGINAL: lee172
RE: THE LOUNGE 2
Ok just so we are clear on the Rx issue.
AM - you should be able to use any manufacturer's crystal.
FM - JR/KO are positive shift. Futaba/Hitec are negative shift. If it's single conversion you should be able to change crystals that on the same shift.. BUT if you have PCM/Dual conversion systems. I would only use the stock crystals. They are not alwasy interchangeable.
2.4GHZ - Only OEM Rx and only air to air and ground to ground. Except JR/Spektrum which are the same company. Nomadio can use the very first Spektrum ground Rx.
IL
RE: THE LOUNGE 2
Right. So I want more offset on my E-Sav wheels, and have a minor conundrum. So I will turn to the respectable masses in The Lounge to offer their $.02 (or GBP .02).
So...I currently have 14mm alum clamp hexes on the truck - I love clamps, cuz it really annoys me when I'm taking a wheel off, and it's a bit stuck, so I pull, and the thing pops off, the hex falls, and the pin goes flying. Or I take the wheel off, and it's just easier not to have to pull that pin out and set it aside when I work on the truck (so it won't fall out on its own). In short, I like the clamps.
I also want to keep my HPI GT tires, and stick with Maximizer beadlocks. The only offset 14mm Maximizer beadlock option seems to be the X-75, but I'm not sold on the looks:
http://www3.towerhobbies.com/cgi-bin...6&I=LXNWP2&P=K
My other option is to go with a 17mm Maximizer that looks nice, but I'd need to get 17mm hexes. They don't make 17mm clampers though, that I know of.
http://www3.towerhobbies.com/cgi-bin...6&I=LXNWR1&P=K
What to do, what to do? Is the X-75 so hideous that I should just forget my clamp obsession and get the 17mms?
Discuss!
Discuss!
RE: THE LOUNGE 2
Eman, take a look at this page..
http://www.junfac.com/shop/index.php...=index&cPath=7
See if you can find a combination of widener that would work w/ your wheels of choice...
You can run 12mm clamp hex, and do a 12 to 17mm widener.. for example..
Of if there's 23mm wheels that you can use.. then you can do the 14mm to 23mm setup..
IL
RE: THE LOUNGE 2
LB - yeah, I considered an adapter, but am afraid that would be sort of a weak link or put stress somewhere else? Not sure. Plus I think I'd rather save cost than go that route.
Secretsg - I was thinking that too. Lots of Savage guys went 17mm w/more power, perhaps that will answer my question for me.
RE: THE LOUNGE 2
Sure Eman, if you can avoid the widener, I'd avoid it.. but just saying that's another way of attacking the issues.. and some "adaptor" are not widener.. they are just adaptors.. So that shouldn't add more stress to your C-hub, steering knuckles, etc.
IL
RE: THE LOUNGE 2
ORIGINAL: Lunchboxer
I think I'll just go 17mm, and stop whining over not being able to use my nice shiny purple alum 14mm clamp hexes. *sigh* *whine*
So........which 17mm "adapter" to use? I'm leaning towards HPI (not sure about those "composite" ones' durability):
http://www3.towerhobbies.com/cgi-bin...6&I=LXSCH9&P=K
http://www3.towerhobbies.com/cgi-bin...6&I=LXNWS3&P=K
IL
RE: THE LOUNGE 2
Awesome.
Now who's giving me $200 in Tower gift cards? Eh? Eh?
Seriously though, thanks folks. I like bouncing ideas off of the group now and again, to see if others are thinking what I'm thinking, confirming suspicions of mine, etc. It helps.
IL
RE: THE LOUNGE 2
I agree.
I just want too much stuff. Someone send me $$.
Heck, I still want you to paint a new Durga body for me Auto, but it's just way low on the priority list since I dove into the E-savage BL project and am over budget.
IL
RE: THE LOUNGE 2
Wonder if I will get any $$$ back from the tax this year!! [:@]
