THE LOUNGE 2
RE: THE LOUNGE 2
ORIGINAL: rcluke
seriously,
i want a MM, but i'm not sure which one to go for, to say i will be using the car on carpet, then wood
ORIGINAL: Lunchboxer
Not sure if there's an equivalent turn.. LOL.. I have not seen a brushed motor going 45-50mph.. LOL!
RE: THE LOUNGE 2
For touring car, I'd go 7700kv, unless you plan to run 3S lipo or something like that..
For 6-8 cells, 2S lipo, 7700kv can not be beat!
ORIGINAL: rcluke
seriously,
seriously,
RE: THE LOUNGE 2
ORIGINAL: rcluke
seriously,
seriously,
i some-how don't think the 7700 will be sensible, i was thinking more like the 5700
IL
RE: THE LOUNGE 2
ORIGINAL: secretsg
No problems with stormer. It's been around for a long time. If you need to you can even grab a hold of the owner on RCTECH.
The Front rims list a bearing size on Imex's site, so I'm guessing they take a bearing. The Rear rims list a hex size (which fits the pede). I'm guessing I'll be ordering 4 rears (Pede front bearings are in the carriers, not the wheels. They have a hex up front for the wheel). My other concern is that offset is sensible enough so that I won't have problems on the Pede.
RE: THE LOUNGE 2
Nice R8R there, but very surprised that you didn't just keep it in the box........ (next to your 34 NIB, ha ha ha!)
RE: THE LOUNGE 2
Why not try the XBR 8.5?!
Since you are racing..... sensored setup might be better..
i haven't got loads of money to throw at one
RE: THE LOUNGE 2
ORIGINAL: lee172
i do have one NIB, plus two bodysets (just in case!) the R8 is definately a shelf queen, dont wanna bash it up like the rest.
RE: THE LOUNGE 2
XBR 8.5 is cheaper than Mamba Max combo.. but a little bit more than the Sidewinder...
If you are really on budget, and you only want to go up to 5700kv, the Sidewinder might be a good deal for you..
I installed it in my M-03M, you can go check out the thread...
ORIGINAL: rcluke
how much are they though?,
RE: THE LOUNGE 2
Got any hop-up planned for R8R?!
I wonder if the F103GT motor plate / heatsink works on it!
ORIGINAL: lee172
RE: THE LOUNGE 2
ORIGINAL: rcluke
can you post a link for the XBR8.5 and the sidewinder
RE: THE LOUNGE 2
They are both available at Tower..
Sidewinder is basically Mamba Max's little brother and can do 4600 and 5700kv motor.. but not the 7700..
But is a bit cheaper!!
RE: THE LOUNGE 2
i forgot where i got the XBR 8.5 from.. i think it was Tower??
http://www3.towerhobbies.com/cgi-bin...&I=LXRST1&P=ML
if i were you i'd try the super smooth Novak..
RE: THE LOUNGE 2
I think you should try them all!! I'd have to say that the sensorless is getting better! And obviously, offer the great power..
But for racing, I'd say sensored would be the way to go! If you ever got spun during the race, you can get right back up right away..
The sensorless can almost do that now, but still, you feel the slight hestiation at starting.. worse when the car is rolling backward, for example..
RE: THE LOUNGE 2
Maybe time to go to the main forum and do some reading.......
But basically, sensored has a sensor at the motor that tells the ESC the rotor position so it can accurately fire the pulse.. while sensorless does not.. it uses some mathmatic algorithm to estimate that...
ORIGINAL: rcluke
what's sensored and sensorless?
RE: THE LOUNGE 2
I assume the TRF415 is used.. the TB-01 is NIB / discontinued...
Just my guess...
Just my guess...
the bloke has 2 TRF415's
i'm not complaining though lol
RE: THE LOUNGE 2
ORIGINAL: rcluke
also, is there any discount vouchers for tower?
