THE LOUNGE 3...
RE: THE LOUNGE 3...
ORIGINAL: Ttam Says Blarg
FG is broken...! What happened?
I dont think you can continusly run tank after tank. It can be hard on it, because they run for 30mins.
So if he ran 3 tanks of fuel that's 1 1/2 hours of continuous running.[&o]
MA
RE: THE LOUNGE 3...
Nope. 5 mins of running did it in. The previous owner hacked the thing together. The motor mounts would constantly come loose and screw up everything. The gearing was probably too high for the massive wheels and the smallest motor. And I have no idea how old the motor is. When I brought it over to me it was way under power and smelled real bad. It was smoking and just died. I tried to start it later but no good. The FG is going to be put on the bench until I get the funds to fix it. It needs a new motor, alloy engine mounts, all new hardware, gear carrier and low end gears. It was fun while it lasted but its going to have to sit for quite awhile.
RE: THE LOUNGE 3...
haha, i think this is... i dont know what this is, but i think i want one http://www.gamestop.com/pc/accessori...ng-mouse/77762
RE: THE LOUNGE 3...
ordered [link=http://www.gamestop.com/accessories/sharkoon-x-tatic-true-51-dolby-digital-surround-sound-gaming-headset/84306]these[/link] last night along with a black dsi. should be here tuesday. hope didnt overpay, but as long as they are notably better than my sony mdr v150's i will be a happy camper. heck, i'd be happy if they are the same quality speakers (although 4 of them in each side) with a better headband.
RE: THE LOUNGE 3...
yeah, i wasnt even really looking for headphones, i was just looking around the site and came across them. i bought them because i damaged my cheap-o v150's ($20 at walmart) and was intersted in both a better set of headphones and a surround sound. i googled them and ign did a review of them and they spoke highly of them (and they are not afraid to insult products), so i bit. the reviews seem to indicate they are equal to a decent quality budget (~$300) home theater-in-a-box as far as sound goes.
RE: THE LOUNGE 3...
ORIGINAL: AutoXMan
Man all this reading about your FG makes me want to pull my gasser out, that's todays goal!
RE: THE LOUNGE 3...
ORIGINAL: Lunchboxer
Who needs cold air induction?!
RE: THE LOUNGE 3...
ORIGINAL: DarkFire989
Baja spur gear is destroyed. Great weekend so far.
Not sure why I always ruin them. I set my pinion/spur spacing using the classic dollar bill method, clutch isn't too tight (actually a bit looser than stock), and I threadlock the motor screws to prevent back-out. None of my other cars have this problem, not even the Dark Impact, which is 4WD and doesn't even have a slipper.
RE: THE LOUNGE 3...
ORIGINAL: mechanizeddeath
I destroy my Stampede spur gear roughly every other run... To the point where now I keep 2 or 3 on me at all times. They're cheap, less than lunch at a fast food joint, but still it's annoying to have to replace them so often.
i'd swap it for a RR spur. i have only stripped those when i was being an idiot or forgot to set the mesh right.
RE: THE LOUNGE 3...
Yeah I should probably just buy a non-Traxxas one, that's most likely my problem.
It's funny because the overall design of their cars isn't bad, it's more like the quality of the basic parts that compose them.
CA
RE: THE LOUNGE 3...
Made a couple hundred dollar gamble on my Sherline 4th axis today to make it fit 1/2" stock and low and behold, it paid off . Now im a lil bummed though that they make the silly thing from mild steel... ooh well it still works [8D]
RE: THE LOUNGE 3...
RE: THE LOUNGE 3...
Hey Calvino what kind of milling set ups you usin anyways? And cnc programs, which ones of those? You mentioned 3d, most ive ever used was basic G and N code or conversational
