video test
Your top post I see the issue.
The second is from a laptop with 800px resolution. As much as we would like to be able to support all devices and resolutions, there is no way we can do that. If a screen can't display enough *screen* this will happen.
But I will investigate the issue of squeezing the screen for videos in top post, as well as the mobile squeezing issue.
Nonsense !
It's at 1024 right now and if I increase it the display is way to big for the screen.
Everything was fine here until three weeks ago when "someone" decided to code the first post of each page to have an ad.
Not much research to do if you ask me. Just remove that ad placement in the first post of each page and everything will be fine. I believe most will agree that we can put up with the new ad column on the right side but not having an ad in a post compressing the type and attachments.
If you click on the actual ad's "x" to close it, it gives you the option of sending feedback about the ad's placement. Of course if you are blocking the ad you can't do that.
What we have is a few cases where the ad is troublesome:
1. On a mobile device when not using the mobile skin (if you use the skin -- no ads in posts).
2. On all devices when a video is posted in the first post.
The number of threads that start with videos is very, very small. Nevertheless, we will see what we can do to fix that.
As to the mobile issue, I am also looking into that.
Let's not make this out to be a bigger problem than it is. The sky is not falling because there is a square ad in a post. We have some glitches, and we will address them and move along.
Thank you to all who have reported on this, and especially those who have posted screen shots. Very helpful in fixing this!
Paul
Paul
Nonsense !
It seems the moderators are ignoring the elephant in the room. Users are complaining about the ad placement in the first post of each page in every thread yet no one is addressing that issue or acknowledging the fact that simply removing the ad placement will solve the problem.
A "big phone screen"....what is that supposed to mean? I've been using the same two laptops since '07 with no issues on this or any other site until three weeks ago.
