edge vs. yak
RE: edge vs. yak
Really it comes down to what stage in your 3d skills you are at. I tell people if you are new or just honing your 3d skills get the OMP Edge as there is no plane as stable and easy to learn 3d with. The Yak is a little more loose in the air but this gives it much more yaw authority. The differences in these two plane is the difference between a sunny day at 75 degrees and a sunny day at 80 degrees. Not that much.
