GS Edge 540 questions
My Feedback: (19)
I recently bougt an ARF and I dont have the CD that came with it. Can you tell me the CG, specs on servos recommended, control horns recommended, and any other tips I need to be aware of during final assembly. The plane is pretty much together except control horns, servos, engine etc. I have a OS 160 that should be perfect.
RE: GS Edge 540 questions
The ARF should have included the CD and the control horns. Did you get the ARF from us or second party?
Anyway the CG should be 1 - 1.5 inches behind the wing tube. Servo torque ranges from 90 minimum to 150 high end.
