65" Yak
FL
65" Yak
got the Yak in the bones. I also never saw the rib doubler for r3 I did make extra support with scrap 1/16 ply it looked like it needed it.
I did have some other minor problems
if you look at these ribs wrong they will break, the wings would be easyer (stronger) to build if the ribs were a bit heavier. it might add one or two oz. , or add none considering the extra glue needed to fix broken ribs.
the directions say to be carefull cutting sticks ,to use the short scraps first, but I still did not have enough 3/8 SQ. or 3/8x1/4 add these two more sticks.
Let everyone know in the begining of the directions the need lots of epoxy, cups, stirrers and micro ballons. I mixed epoxy so many times I lost count. Using 30 min. would cut down on the # of times to mix but it takes so dam long.
over all it looks good and seems light Here are the Photos
FL
RE: 65" Yak
more photos
here Is my setup
os1.20 four stroke
16x4w apc prop
Hs605mg alerions
digital hs5625mg in tail
hs225mg throtle
futuba pcm receiver(9cap)
6 volt 1050 NiMH
here Is my setup
os1.20 four stroke
16x4w apc prop
Hs605mg alerions
hs225mg throtle
6 volt 1050 NiMH
FL
RE: 65" Yak
Mike, I would not change a thing. The ribs are plenty strong. I want a kit that is built to fly not built to crasg. If ribs break because someone is looking at them wrong, my advice would be "stop looking at them wrong".
