Help - curve in fuse
OH
I am building a 47" Yak kit and have a curve in the fuse. I followed instructions in assembly, but obviously did something wrong. When laid flat, the center of the fuse is probably 1/8-1/4 inch off of the table while the ends are touching. Can I straighten this out or should I start over? I do know my table is flat.
RE: Help - curve in fuse
While building the bigger YAK I got carried away with the gorilla glue and wound up with waves in the fuse. Was able to get some of them out by reverse bending with weights and misting with water. Never go them all out tho. You might want to try that as it might help. If you can get it down to 1/8" I would fly the heck out of it. Some are off way more than that after repairs.
Ed M.
Ed M.
Bentgear really states the only way we know of to unwarp structures. You can try wetting with water and ammonia and weighting in the opposite direction. If this does not work then you will need to build a new fuse. It's important to assure you not only have a flat table but a sturdy one as well so it won't bow under weight. Also be careful with how much glue you use and do both sides at the same time instead of one first, cure, and then the other one.
OH
Thanks Mike. I will try that. I have no idea how this happened as my table is flat and very sturdy. Also, I did do both sides at once as instructed in the manual. If I do need to build another fuse, what would the required parts cost? I would need the core, sheeting and the edge material.
Now I am thinking I should have gone with an ARF instead of a kit. Do these come in ARF's?
Dean first wet it and weigh it down again. But weigh it down much less this time to make sure it's not your table that is giving in under the weight. I was able to get my fuz sorted this way as I had the exact same problem. My friend's fuz is still warped but we're making a plan with it now. You might think your table is sturdy but yes facts are they sometimes simply are not. You won't need all the weight now as the sheeting is already glued.
SC
I did the same thing with my GS540P. I had a pretty substantial LEFT bow (ouch) because I used a hollow door blank which was perfectly flat, but bowed in the center under an estimated 150 lbs of weight. I sanded off one side (right side-opposite) of the balsa and resheeted it. This time on a really flat, really rigid surface with all the weight I could get. My wife wasn't pleased to find out the dining room table wasn't usable for several days due to the fuse being on it while curing. Balsa sheeting is pretty cheap, and in my case, it was more a matter of this fix taking less time than ordering a new fuse and starting over.
Doug
Doug
Doug,
That's a really good idea for a fix. Must have been fun sanding off one side of sheeting. Hope you didn't do that part on your kitchen table or elst yee may be sleepin' on da couch!
