Katana ARF Fairings
GA
Katana ARF Fairings
My right side fairing is not fitting flush against the wing. I have taken a closer look and I have noticed the fairing on that side of the wing is a bit "off". More than likely caused by stretching the monokote a little too tight causing the wood to warp slightly. Will this cause a problem or should I just trim away the monokote as needed and force it to fit flush by pushing on it while the epoxy drys?
