shockflyer questions
i recently purchased one of your shock flyers with the 3d power set and i was wondering if u guys had or could recomend a speed control for it and a battery pack?
RE: shockflyer questions
If it is the normal brushed 3D power set you are talking about. You can get away with an ESC of 10A up. Try to get a speed control without a brake and in the range of 10A to 20A max otherwise they become heavy again. For the battery I would only recommend the Kokam 3s 340mah or something similar. 11.1V is a must and avoid getting a 700mah bat because of the weight of the bat. Try and get the 340mah.
