OMP 540 foam fuse?
MA
OMP 540 foam fuse?
Hi,
I recently broke my balsa fuse (behind the wing, where else) on the edge 540 (40-50 size).
Is there a foam fuse available to order as a replacement?
Love the plane. Rob C.
RE: OMP 540 foam fuse?
Rob, yes we can set you up with a new foam core or fuse kit or whatever you need. Really though one of the beauties of the solid foam core fuselages is the ease of repairing. Just peel away the covering, squeeze some urethane glue such as Elmers or Gorilla glue into the crack, set the fuse back together flat on your board and clamp until dry. Sand the excess glue away and recover as needed. Much faster than building a new one.
