OMP Katana RTF Problem
LA
I purchased the Katana RTF last week. It came in today and i had no problems putting it together. When i hooked up the battery to the speed control, I did as the instructions said and had the throttle down in the idle position. After the beeping stops, when i advance the throttle, it will pick up speed and then shut off. It wont go above half throttle before cutting off. Is this something i did? Is there something i can do to fix it? This is my first electric plane... so all this is new to me.
Any info is appreciated.
My Feedback: (16)
IL
Not trying to be a smart ass, but did you charge the battery? Sounds like the LVC kicking in and powering down the motor. If the battery is charged, try checking the cut-off level on the ESC (make sure it's set to the cell count you're using).
throttle stick down, plug battery to ESC, throttle all the way to full and down again.
than start open throttle easy again, see what happend. that should set off to normal position the speed controller.
wttiger, Are you the gentleman I spoke with over the phone? Please email me at [email protected] and we'll send you a new esc.
