Hey Mike - The wing root wedges worked!!
My Feedback: (23)
CT
You might remember me as the guy who had the eye problem where I had some trouble getting things perfectly straight (the wing tube / root rib in my Fusion 52 [>:] ).
Anyway I used the parts you sent as a template, cut some 1/4" balsa slabs, glued them to the roots & sanded my brains out (didn't take too long so I kept sanding). I managed a reasonable taper front to back.
Bottom line is that the wing now fits like it should with no glaring gap-o-sis - I am going to try to finish the Fusion as far as covering & trim & post some pix before my surgery next Thursday.
Thanks for all your help Mike - next I am starting an Edge 540 (foam bidy) - after that a biplane!!! I sure do love OMP kits.
