67" Fusion F3D leading edge radius need help
AZ
I have lost the part of the plans that have the radius of the leading edge so I need to know what the radius is at the root and at the tip this is for a 67” Fusion F3D kit.
Here where I am hope to fly it soon
Thanks in advance Tom
RE: 67" Fusion F3D leading edge radius need help
The radius should simply be a smooth contour from the top of the wing to the bottom of the wing. Use a combination of razor plane and sanding block to achieve the above. The radius will get smaller slightly as you get towards the tip as the wing is thinner.
AZ
Thanks Mike that’s kind of what I figured but just wanted to ask anyway, I cut the pattern out and put it in a safe place if I could just fined that place all bet there is all kinds of goodies there.
Thanks Tom
Thanks Tom
