OMP - Ohio Model Products Support Forum Discuss products and get support from OMP. This forum is operated by the owners of OMP and your support questions or complaints will be handled as OMP deems appropriate.
thrust plates
Old 10-22-2008 | 07:22 PM
Default thrust plates
how can i add right thrust to my yak55 65' without buying the plates?can i use washers on the front of the engine,if so how many do i use to get the right amount?any imput will be appreciated.
Old 10-22-2008 | 08:17 PM
AFSalmon's Avatar
Default RE: thrust plates
Just put a couple of small washers under the front two bolts and that should do it.
Old 10-22-2008 | 09:07 PM
will that be 2 washers on each bolt or one washer on each??
Old 10-23-2008 | 04:45 AM
Murdoc's Avatar
2 on each
Old 10-23-2008 | 04:58 PM
And I thought I was cheap...
Herb
Old 10-23-2008 | 08:26 PM
cheap??? i am not gonna buy them for $2.50 and pay more in shipping than they cost.
Old 10-24-2008 | 06:55 AM
AFSalmon's Avatar
ORIGINAL: edge540l
Rob, most folks buy them along with something like a plane or engine. Plus you can slice these plates with your bandsaw into 3/8" wide pieces and use them for 3-4 planes. They provide a nice hard and continuous surface to mount the engines to. Eventually the washers we all used in the past dig into the wood. Go ahead and use the washer technique but you may have to add another to take up the compression over time. Really though it isn't that critical.
