55ax
have a 55ax on my pro yak with a 12.25x3.75 lhs will not have any 13x4 props in for a month so i ordered one through swanyshouse.is there a difference in the xroar wood over the plastic apc props,what should i notice with the wood prop
Tower Hobbies has them. I got a 14x6 S2 for my Saito 82 also. It likes that a lot..... was using a 14x4W APC and you'd think that S2 prop would be too much for it but for some reason the way the S2's are made they load the engines differently. Same goes for the APC vs S2 on the 55AX's.... the 13x6 S2 works like a charm.
You can always have your LHS order a couple of them for you. The price is nice compared to the APC W ones also.
Ernie
Ernie
My Feedback: (57)
IN
You are the only one. Many would argue the 55AX is the best 50-60 size 2-stroke on the market.
Unreliable usually points to the glow plug or air in the fuel from vibration. The stock muffler, while a bit heavy is very good.
13x4 IS the prop for 3D below 2000'ASL.
Here is a guy that can prove it. I don't have any video of mine.
[link=http://www.smilexpress.net/photos/RC/vids/McDDD_chinn_yak_don%27t_look_back_hi.wmv]McDDD - OS55AX - APC13x4 Video link[/link]
My Feedback: (57)
IN
That's actually a Chinn Yak but it isn't the plane that makes that video great. It's Dave's thumbs.
Mostly it was to point out that a 55AX with a 13x4 is a great way to go on a 40 size 3D machine in the 4lb. zone.
really i have a 55ax and have a ton of flights on it and never gave me a problem,now my 91fx will never run the same from tank to tank where the 55ax runs smooth all day long and is a power house,got a xoar 13x4 prop and will be trying it out tonight
well tried out the 13x4 xoar and it really woke the 55 up spool up is insane and it will hover between 1/4 to 1/2 now.gonna order a 15x4 for the razor yak,which will be for sale,or will trade it with the 91fx for another proyak with a 55ax no servos just airframe and motor with the razor yak
Hey ThumSkull, which series is that MA 13x4 you are talking about. I want to try one of those as well as the as the 13x6 Scimitar S2 that is working great on my Fusion.
Ernie
Ernie
My Feedback: (57)
IN
Swany's house carries the Xoars.
[link=http://www.swanyshouse.com/xoar/props.aspx]Swany's Xoars[/link]
also
[link=http://www.texas-hobbies.com/props.htm]Ian at Texas Hobbies has them.[/link]
also
