omp katana v2 46 help
Hey guys! I just finnished the assembly of my new katana v2 46 arf. In the package, I did not find a manual. So I wondered if anyone can help me with the cg location on this model? Also, on the box it says rtf weight is 1850 grams, my ended up on 2156 grams. Will My 46 2stroke be powerfull enough to hover this plane?
My Feedback: (57)
IN
ORIGINAL: Murdoc
ORIGINAL: ThumbSkull
Use a Xoar 12x4 on that 46. Should hover with some pullout. Start at 33% of wing cord including the ailerons for CG. Trim for level flight then invert. If it dives, nose heavy, if it climbs it's tail heavy.
ORIGINAL: Murdoc
Thanks for taking your time to help me
I really dont understand why it came out at 2,2 kg. I used standard futaba servos for the ontrol surfaces, and a micro servo for the throttle, 9grams receiver and a 4,8v 1100 mah rx battery. So the weight is very strange I think.
I
Sorry but I have never seen an email from you regarding this question. So either wrong email or it is not getting through. Regardless though the CG for the old Katana would be as described above and around the 33% MAC location - as it is for almost all the funflys and aerobats. On the Kat46 that was about 5.25 inches back from the leading edge at the root.
ORIGINAL: Murdoc
I sent omp 2 emails, they never replied. Why dont you reply omp`?
yeach, mine too. I just finished installed the kit and I got auw about 2.2kg with no fuel. I'm not glad with this . I remember to my first katana is got 1.8kg more than 5 years ago. easy to hover with my os 46ax. I think It's contributions of wider wing, more more weight on fuselage. so what is the advantage v2 than the first version? very dissapointing.
