LED lights
Night flyers
Just wanted to let you guys that fly at night know that BPHobbies has received a shipment of the BP Hobbies Flexible High Intensity LED Light Strips.They are easy to use, super bright, peel / stick, and modular. Available in four colors – white, red, blue, and green, these strips are 100 cm long with 60 high intensity LED lights. Each strip comes with a two wire lead so all you have to do it connect the leads to a power source of 6 to 12 Volts (2S/3S A123 or 2S/3S Lipo). The LED lights are wired in groups of three enabling you to cut or add lights to customize your setup. Remove the backing and stick to almost any surface. Make your fuselage glow, light the wings, creating landing strip lights, or dazzle up your helicopter canopy. http://www.bphobbies.com The price is $8.95 each.
