Need Help!!
CO
Hi E Fliers.
I'm very new at Electrics and have much to learn. My biggest problem right now is my MP Jet 25/25/26
Cuts out on full throttle on certain battery packs.
I'm using a Jeti 18-3p Seems like 7.2 is OK, 11.1 LI-PO,s
seem OK but 9.6 NiMH of different AH's cut out. Volts check out OK and I'm only @ about 3 to 4 Amps. Any thoughts for me?
CO
Hey Jason.
Thanks for the interest! Yea, I have a couple of them and they both react the same.
Its wierd, less volts no problem, same with more. just eight cells.
Have you tried all these set ups at the same field? What kind of RX, there are some RX or ESC that when the RX hicups the throttle is cut to prevent the plane from flying away. Are you using the same type of connectors for both type of batteries? or are you using an adaptor? I can't think of anything else, that's my 2 cents.
CO
Most of my tests are done on the workbench.
I am using the same connectors so ?
I just recieved my new shulze charger so after I buy the necessary cables ( Hey for $189.00 you cant expect cables too! ) I will try to analize my batteries better and see if I can nail down my problem.
Thank for the Hints.
Earl
Earl
