Potensky Eagle power problem
Hi
Am having problems with under power with my Potensky eagle as well. I am using the stock motor and ESC with a li-ion 2cell 7.2v 1400mah battery and it just barely climbs. What will be a better battery to use with the stock motor to get a decent performance possibly hover?
KS
I don't know the answer, but you might find something useful here http://www.gregcovey.com/aerobati.htm
scroll to the bottom. Be sure to check the links he has to E-Zone near the bottom as well.
I am using a 10X4.7 at the moment. I will try a 10X7 see if I get a better performance. the rpm just wont go above 4700 and the spec of the motor says 5600
