gws zero
gws zero
Yes I do Sean. This plane is the shiz! Make sure you use an 8.4V or higher battery with at least 350 mah. With that the Zero will do any tricks you can think of inverted, emalmens, loops, rolls, etc. Make sure you do a range check because the Zero goes pretty fast with a big battery. Have fun with it, I know I am!!!
gws zero
......Building tips scott88 building tips not bragging rights>!
well this plane is quit good in the air with an 8.4 pack in it. make sure you use rubberbands on the fusalage. It'll peal the paint off it you use tape,(ugly mess) Get all your settings right on the plane, keep the aileron settings low for the first few times, make sure the battery is sucure(foam from paking works great), get the cg perfect and just have fun!! you bought a great plane now unrip is awesome aerobatic purpose!
