TIGERMOTH ORIGINAL HELP
VA
Is there a Futaba or HITEC that can be used instead of the GWS transmitter servos receiver
and battery in the original tigermoth.
All help appreciated.
Thank you
James
Thank you
James
OR,
In my TM, I use Hitec HS-55 servos, Castle Creations Pixie 7 ESC and used a Hitec 555 receiver in the past. As far as receivers go, I have converted to Berg Microstamps as they are small, light and seemingly bullet proof. Most of the Futaba gear is too large and heavy for the Moth.
