Noob ?
NY
I'd like to use the metal (things...
) on the top of the servos pictured below, what are they called?. I want to use these instead of make a z bend. This is on a Slow Stick.
MI
Generally called a "Screw lock connector" regardless of the brand name. You want to make certain the locking screw goes all the way down and tightens on the wire; some of these won't tighten on small dia. wire; also some have burrs in the threads that prevent same.....Jim
