Stryker help
IN
Hey guys, I just swicthed all my crashed stryker parts over to a new fuse. My antenna wire came loose from the esc anyone know where this connects at? It was just stuck the 2 sided tape on the bottom of the esc. Stock bird here.
Thanks Tim
Thanks Tim
FL
Tim,
If it pulled out of the rx, you'll need to take the case apart. Look at the case and you'll see a hole in it where the wire came out. Once you take the case apart, look in that corner of the pc board, you'll more then likely see the remains of the lead there. The lead goes in a small hole on the board, loops over and then is soldered to the board. If the lead broke off flush, remove a tiny section of the insulation on the antenna, tin it with solder, and resolder it to the board. If it broke off long enough, just solder the 2 ends together and cover it with a piece of shrink wrap, and you are good to go.
IN
Ok took my plane out this morning{first time since last year been flying modded challenger} and I flew her very excited!!!!
Question is does anyone know what size screws are used to hold the motor to the motor mount?
Cant buy them anywhere it would help if I knew the size!!! Local hardware stores dont sell anything that small!
