Park Flyers & Backyard Flyers Discuss RC Parkflyers and rc backyard flyers in this forum
battery ?
Old 07-23-2006 | 04:06 PM
3DSAVAGE's Avatar
Default battery ?
i just put a brushless motor in my formosa and i need to know if i can still use the 730mAh nimh that i used with the stock motor. if so, how long will it run? the motor is an eflite 400.
Old 07-23-2006 | 08:08 PM
Default RE: battery ?
You can run the battery, you just won't get the full potential out of the motor and it will also weigh a bit more vs using a lipo. On my Typhoon, which also has a brushless motor, I run both 9-cell NIMH and 3-cell Lipo packs.
Old 07-23-2006 | 09:18 PM
3DSAVAGE's Avatar
would my tp 730 li po work on it? wat is a good mAh for this motor?
Old 07-23-2006 | 09:42 PM
SS2P's Avatar
Mah is not the important thing, important is the discharge rate and continous current. 3 cell, right?
Paul
Old 07-24-2006 | 02:14 PM
3DSAVAGE's Avatar
yep
Old 07-24-2006 | 03:49 PM
3Dsavage, I run a BP21 and 3S 1300 ma 12C batt and a 7X4 folding prop on my formosa, this set up flies good and gets 12 to 18 min flights at 1/2 to 3/4 throttle, you should get 5 to 10 min from a 750 on the 400, depending on your prop size, a 5X5.3 makes the formosa a screamer with the 400 motor
