looking for something to fly around in the yard
VA
I don't have much room. I need something that flys slow and can land on the driveway in about thirty feet. I'm looking at the E-Flite gypsy and using a 370 brushless system on it. Anyone experienced with it?
RE: looking for something to fly around in the yard
ORIGINAL: suitcase
What kind of flight are you looking for? Aerobatic, Glider, Wing? There's several that can be flown safely from your drive way. It all depends on what you want to do when you get up.
My .02s
I still think the best off the shelf small area flier is the GWS Pico Tiger Moth. If you build it light and use lipos you can fly it in a small area and it will zip around trees and other objects in a large back yard or cul de sac. The down side is that it is a calm air or just a little breeze plane. With a 700ma lipo they will fly for a half hour plus. Not a beginners plane though as they are a little fragile but also a light plane doesnt crash as hard so its kind-of a trade off.
Good Luck in your search
Bob
Bob
I agree soarhead,
My friends and neighbors get a kick out of a little "barnstorming" show I do with my TM. I fly it "on the deck" popping up over bushes and small trees, narowly missing my house, turning around over the road, under wires, and flying inches over the dogs head. It slow, agile and remarkably durable. I have flown it into a stopsign with no damage. I dont have lipo power, can't loop it but still its a blast. It can turn inside an aero ace and if I have to put it down in a hurry, I just plunk it into a shrub.
Sal
Sal
are there any good planes that you can fly round your living room?
Ive seen a few very cool articles in Fly RC bout micro flight but they are quite expensive.
CA
ORIGINAL: drunkenbushman
CA
suitcase, have you tried an aero ace? I know it's only 2 channel, but if you do the single stir stick mod you can get it to fly pretty tight. In the right conditions I can get mine to flip turn. It is nearly indestructable, and can be flown in moderate winds. It's also only $30.00. I'm refering to the biplane model. The jet model is not as responsive. I fly my aces from my front porch. Range is between 100-300 feet, depending on throttle use 10-15 minutes of flight time. Check out the thread on electric indoor & micro fliers. Good luck, Tim
http://www.airmidimicros.com/AMMPlantracoMR.htm
this is another option. My brother is currently waiting on a receiver back from these guy as his needed replacing... haven't seen it up in the air yet but it looks promising
CA
Packyj, I keep thinking that I should order one of those planes. Then put Aero Ace gear on it. Is that what your brother plans to do? Or is he using the plantraco gear? I'm thinking about buying their gear, but if it is not easily transferable or unreliable, I will think about other options. Tim
sal 37, I doubt you can turn inside a stir stick mod Aero Ace. But that is the inventer of the mods coming out of me. Tim
He's got the plantraco gear at the moment, aa guts is a good idea and the airframe would probably do just fine with it... not sure about using thrust vector steering on it but i can't imagine anything detrimental with that idea
CO
Take a look at the Mini SpeedWing EX. That is just the type of area I designed this wing for. It can fly at a fast walk and doesn't stall, even with huge control throws (I set mine at about 80 degree deflection).
Check out the video on my videos page: http://www.speedwing.net/videos.php
-- Acer
http://speedwing.net
-- Acer
