Park Flyers & Backyard Flyers Discuss RC Parkflyers and rc backyard flyers in this forum
Best prop for F-27C Stryker
Old 01-08-2007, 11:00 PM
LT-40
LT-40's Avatar
Default Best prop for F-27C Stryker
What is the best prop for the Stryker with the stock motor, stock li-po, and stock 25A ESC? I broke the original prop today, and I was wondering if now would be a good time to experement with different props. I believe the stock prop is a 6x4. Also if a 6x4 is the best prop, then is it ok to get an APC or other brand prop, or should I stick with the Parkzone one? Does anyone know if the stock prop is a regular prop that is reversed, or is it a real pusher prop? When shoping for a new prop should I only buy pusher props, or do the normal ones work good?
Thanks for the help, and this plane rocks!
LT-40
