hz super cub w/ typhoon gearbox
NC
i was wanting to build a a cub on gws floats with the typhoons gearbox, motor and prop i do not have the air frame yet but do have the gear box and motor. is it a easy match up for the fire wall?
RE: hz super cub w/ typhoon gearbox
From what I understand the Typhoon motor/gearbox is a drop in and has the same screw hole alignments.
Here's someone that has converted over to brushless using the Typhoon Brushless power:
http://www.rcgroups.com/forums/showp...postcount=1562
Here's yet another conversion:
http://www.rcgroups.com/forums/member.php?u=106813
NC
well i got the gearbox mounted with 1 stock hole lower left and tapped two new ones. Im also using a eflite 25 amp esc and a 3c 1800 mah dualsky lipo should I use the typhoons 12x8.75 prop go smaller do avoid a heavy draw
