slow stick propeller replacement
Took slow stick out to fly last weekend. During the landing, broke the propeller (11/8). Can not find a replacement propeller in that size. All on line sights seem to be sold out. What other sizes will work? EPS-300C power system used. 7.2 volt 900mah battery used with Hitec Focus III radio.
Thanks for any help you can give.
cyclone
cyclone
IL
slow stik is the key.can you fly it yet.if so go with the 12x8 prop.this thing just flys,with what ever you want.i put a camera on with 8 cell 1100 mah nimh and it flew fine.stuff the fuse with a piece of wood and crash it as often as you want.just make sure your esc can handle it.then just add cells. FLY OR DIE in Braidwood,il. tom
