Park Flyers & Backyard Flyers Discuss RC Parkflyers and rc backyard flyers in this forum
Battery constuction
Old 06-16-2003 | 07:56 PM
Default Battery constuction
I need to construct a 8 cell 1100mAh battery. Since my charger will only handle up to 7 cells, is it possible to create 2 4 cell packs,
charge them, and then plug the packs together in series to create the 8 cell pack?
It would seem a less expensive alternative that buying a premade pack and a new charger.
Thanks in advance for your replies.
Old 06-18-2003 | 04:33 PM
I charge 2 packs of 8 cells and connect them together so your idea will work well.
Old 06-18-2003 | 06:27 PM
Thanks HR, I appreciate the response.
Bob
Old 06-24-2003 | 03:13 PM
I use dean's and have jumpers for series or paralell add configuration for 24 volts but why not 8-10 volts also. CU
Old 06-24-2003 | 04:26 PM
e-bird,
Thanks for the reply.
What is a Dean's connector? How do they rate to JST's.
I have seen Dean's connectors mentioned, but I am not sure how they are used.
Bob
Old 06-24-2003 | 04:55 PM
Deans is the type of connector used
any on you battery normaly a female
and you plug your controler into it.
Now you make a jumper with 2 males like
on your controler and one female like normaly on your battery then you wire
the jumper in series where you get the
max from two packs in series instead of
one pack. And charge the battery packs
as singles. This email is still [email protected] though CU
