Adding a rudder to a fundango?
Ive been thinking of getting a fundango for a while now (mostly to fly in the vacant lot next door) but I dont like the idea of ailerons and elevator only.
So anyways, I saw a picture of the uncovered frame and it looks like a rudder can easilly be added by cutting the vertical stab right down the center and adding some balsa. I dont think it would add too much weight seeing as a hs-55 (or simular) servo weighs less than half an ounce, pushrods and controll horns weigh next to nothing, im guessing it would add about 3/4 of an ounce for everything. Has anyone did this before? Did it work? was it effective? |
RE: Adding a rudder to a fundango?
Check out the article/review by Kevin Petrilla - [link=http://www.rcgroups.com/links/index.php?id=3839]HERE[/link]
He added a simple rudder similarly to what you want. |
| All times are GMT -8. The time now is 04:45 AM. |
