E-Starter gear
I want to put the following flight pack into an E-Starter. It came from a previous GWS plane. Does anybody see any problems or items that won't work?
EPS400(D) IPS 480 ESC Naro servos RN6II RX 9.6V-NiMh750 Battery If this is a good set up, would the slope glider make more sense then the ARF? Maybe having a spare motor is not a bad idea. Fairly new at building. Any suggestions or ideas would be appreciated. Rick |
RE: E-Starter gear
My Estarter came with D gearing, so you're good to go with that and all the other parts.
The only thing that I've heard complaint about is the battery pack. The 400's tend to be a bit more amp hungry than the 300's and that pack, which I am assuming is a GWS pack, can't deliver a full amp meal for the motor. There is a thread at rcgroups.com regarding that pack between me, some other flyers and a GWS representative. If you really, really, need the link, I can try to find it for you. Nothing there that I haven't said here, but some people just like to read! |
RE: E-Starter gear
Thanks for the info. My battery packs are GWS AAA. What battery do you use in yours? I can always upgrade down the road.
| All times are GMT -8. The time now is 08:47 AM. |
