New heat shrink adhesive covering film for RC plane
Strongly recommend! cheaper , excellent performance!
Width: 64cm(25.19 inches)
Length: All are available Weight: 46g/m2
Gloss: High Gloss
Glutinosity-Heated: Super Strong
On one side of the plastic film is a heat-activated adhesive. It has a clear plastic protective film on the adhesive side. This protective film is removed after you cut it to shape and are ready to attach the covering film to the plane.
You can buy it in the following website:
http://www.aliexpress.com/product-fm...Point_Products
Gloss: High Gloss
RE: New heat shrink adhesive covering film for RC plane
thank you for reminding me. now it's ok.
And sorry for the wrong shipping prices,it is not $25.
It should be $11 or less for 10m covering film.
I will revise price after you place an order.
Others’ Evaluation :
※everything arrived in 2 weeks. and product is good. will order some again soon.
※Covering appears to work well. Shipping cost was more than The cost of covering. Still good deal.
※Covering film arrived a little banged up, but it shrinked well so you can't see the marks.
※Excellent!
※Excellent!
※Very good covering films and quickly shipment. Thanks.
※Good trader goods arrived well packaged in good condition. Would trade again.
※Very slight transit damage,but that's not trader's fault.Very happy to buy again anytime.Many thanks.
※excellent recommend!
※I ordered some black, took about 2 weeks to arrive. it is similar to profilm/oracover to use, sticks and shrinks well and appears to have similar similar strength, I used about 110c to tack it, and progressively up to 150c to shrink, you can certainly get a taught covering at about 135c using 150c to get those awkward wrinkles out. The adhesive is white in colour, I used a wipe of of isoproynol alcohol in the odd place where there was a glue smear, but no worse than other makes of covering I have used, black probably the worse as it shows.I can recommend it, pity no transparent colours
ORIGINAL: Yunxiang Chen
May i ask a question?
what do you call the ''covering film''? ''iron-on film'' or ''wrap film''?
Hope that is what y ou a looking for...
Tom
