Yet another Mousse can post
AZ
Wow!!! I am impressed with the Mousse can, killer throttle response and increase in rpm. I used a Rave 6oz and went to the local hobby shop and bought Aerotrend 3/4" pipe coupler. it barely squeezes onto the can opening. then when it is slipped on to the header , it makes for a very tight fit. no zip ties needed. I am using K&S 5/16" alum. tube for the exit. I drilled the bottom of the can for a snug fit around the tube and flared the tube so no matter if the JB weld doesn't hold, then the flare will keep it from coming out. It is on a TT46 Pro and A Magic Extra. will test this weekend and keep you posted.
Thats the exact same can I used. I had mine tig welded on both ends though. I used an arrow shaft for the outlet. I tell you what..........It sure does light that engine up..................John
