morris penknife
My Feedback: (68)
I need info in how to build the servo trays for the penknife. the plane is framed up without plans. I'm not sure whether to put one or two servos for ailerons. please help
My Feedback: (45)
TN
I can tell you how I'm doing my servo set up on a plane this size... I'm going sheet the bottom center section of the wing with 1/16" balsa. Top will be sheeted as well with 1/32 ply hatches. On the inside of the wing I'm going to run 2 1/8" x 1/4" spruce rails between the ribs. Next I'll cut an opening for the servo and mount it from the inside of the wing...
I think it'll work pretty slick with out adding much weight. I'll take some pictures as soon as I get it done.
Sorry, bad pun...but it's true. Paul's got it right by just adding a few hardwood servo rails in each wing-based opening. The sheeting sounds like a decent idea, although I never needed reinforcement in that area of the plane (I've had several Pen Knifes...and loved them!!!).
-Juhan
for some Pen Knife action:
http://archive.ncsa.uiuc.edu/Cyberia...n_knife_2.html
-Juhan
My Feedback: (68)
no, that was a good pun
I will wing it, I just wanted to know from some of you that have experience with the plane. Usually, experience is the best teacher.
ok 2 or 1 servo for the ailerons. I am using standard servos
thanks guys
thanks guys
My Feedback: (45)
TN
If I was to use the single standard servo setup, I'd put the servo in the middle of the wing and use two push rods from a two armed servo horn..
Don Incoll sets up his Wasp's like this:
Wasp Site
Wasp Site
How do you get to the servo horn screw....through a hole drilled through the fuse (which can't be good on such a thin profile) or is it off center?
I'd also stay away from micros such as the 81. I've used 225s with good results, but you'll need to use the metal gears seeing that the control surfaces are huge and gears easily strip (on tail touches and the rudder or aileron taps the ground, etc). I've stripped three 225s on my Pen Knifes...either use standard servos or 225s (or the like) with metal gears.
Using one or two servos is completely up to you. Looks good with the one setup, although I've never tried it on the Pen Knife. (Thanks Paul for posting that pict.)
-Juhan
-Juhan
