Taco Electronics
PA
I am almost ready to fly my Taco but I have a question. I have a Hitec 555 Rx going in, and I have a Futaba 6xas Tx. How do I hook up the servos etc for flaperson or spoileron mixing. My Tx. only talks about using channels 2 and 6 for 2 servo aileron setups. But of course all I have is channels 2 through 5. Help!!!
David
David
My Feedback: (9)
I'm not positive but, you have to set up a mix so that channel 5 parallels channel 6. You also have to do a mix to cancel out the switch that normally operates channel 5. I'd do the mix to null the switch first so you can verify it has no effect then do the mix to parallel channel 5 and 6. Then when you plug your left aileron into channel 5, it behaves the same as if it were channel 6. The only thing I'm not sure of is if the aileron trim will affect channel 5. I did this several years ago when I had the same situation. I have long since got rid of my 6XS radio or I'd verify how it's done.
basmntdweller
basmntdweller
Look at your manual ther is a setup there.... You must turn on the flaperon in the etup I have done it and it is in the manual,,,, if you need futher help after consulting the manuial PM me
