Irvine 53: Best Prop for funfly/3d
I've got a nearly finished SU-DO-KHOI that is on the resonably heavy end of the scale (thanks to some mods.). Power is to be an irvine 53. I was wondering what would be the best prop for an irvine 53 that would give the plane good funfly/3d style performance?
NJ
RE: Irvine 53: Best Prop for funfly/3d
I've been using MA 12x4's (4 stroke) on all of my 40 size stuff, seems to spool up and hang better than the APC's or wood. The Irvine 53 might work with a 13x6, I haven't stuck one on yet.
Mike
Mike
Banned
11x7 would make the fastest Sud in history! Most ProBros with the Irvine debate between the APC 12x4 and 12.25x3.75, try everything you can get in the range and see what you like. The 12.25 will deliver more thrust for a heavier plane, but it has disadvantages too.
My Feedback: (45)
TN
I'd have to agree... I like the 12.25 x 3.75 apc prop the best on this engine... I also like the 12 x 4 apc and even the 11.5 x 4 apc on hot days...
My Feedback: (16)
TX
ORIGINAL: PaulSwany
FL
are these props sizes funfly types? wide!? or just regular apc's
ORIGINAL: Texas 3D
yep, I was using a 12.25 x 3.75 APC on my Sudokhoi and the Irvine 53. Now I haver the engine on a Extreme stick, and like the 12x4 APC better on that plane. You have to try and see what you like better. No matter what, I would stay with an APC prop for sure.
ORIGINAL: PaulSwany
FL
Definately 12". my boy flew a somethin' extra for a long time on one with a mac's pipe and found a 12-6 apc the best for that setup. on the engine review by clarence lee a few years back, he found the irvine had more torque than any comparable 53 size. We found that to be true, it didn't like to rev like their 46, but had plenty grunt, turned 12-6 like most 40's turn a 10-6. play around some, but try the 12-6; the s.e. weighed about 6 lbs.
My Feedback: (45)
Dave I use the 11.5 -5 Grupner prop with good luck. It is about the same weight as a APC and with 10% nitro it runs fine I also have a Moose can muffler Helps delver the lower spooling RPM. However if I run 15% it will run to hot and sputter giving me warning it is to hot. I may try a 12-4 APC to keep it running cooler.
My Feedback: (41)
ORIGINAL: Born2fly3d
The 12-4 is under propped IMO. It can turn a 12-6 no problem.
P.S. RPMs with a 13-4 at 700 feet (215m) above sea level was 11,600 using Omega 15%. Thrust-O-rama.
ORIGINAL: Dave03B
good 'ol apc 11x7 works well for my irvine wildcard.
Well, i stand corrected. Took the advice by a clubmate to try an APC 13x4 W and it transformed the flying; Vertical at half throttle, control in the (attempted) prop hang was vastly improved.
So, APC 13x4 W or 12.25 x 3.75![sm=thumbup.gif]
