Go Back  RCU Forums > RC Airplanes > Profile and Fun Flying Planes
 OMP Edge 540p kit control throws >
Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
Old 07-10-2005 | 06:34 AM
My Feedback: (25)
Default OMP Edge 540p kit control throws
I just pick up a used OMP Edge 540p and would like to know what the book says for control throws and CG.
Thanks.
Old 07-10-2005 | 07:02 PM
srg123cohen's Avatar
My Feedback: (13)
Default RE: OMP Edge 540p kit control throws
dude its a 3d plane max throws[>:][>:]
Old 07-10-2005 | 08:36 PM
emnm79's Avatar
or not
i'd stick with 45 deg all around maybe less on ailerons, check the omp site for an online manual
Old 07-10-2005 | 08:49 PM
Max on all surfaces on high rate, about 1" each way on low..but i dont have d/r, so its maxed out every flight[>:]
Old 07-10-2005 | 09:12 PM
My Feedback: (25)
Thank's for the info. I put 7 good flights on it today and I have it set to the max on all 45 degrees+. What a plane. It hovers easy, good flat spins and great snaps. I have tha BGX-1 3500 OS on it. Pulls great.
Old 07-11-2005 | 06:43 AM
AFSalmon's Avatar
Congrats! We always set these up for max throws. A good rule of thumb is use the same length control horn on the servo as the distance from the hinge line to the control horn pushrod hole and you will have 45 degrees of throw assuming 100% travel and proper geometry of the linkages. And with most radios you can program in up to 140% on the high rate side for even more throw. I never go low rates on the fun flys anymore but if you want to fly more precision stuff and snaps you can drop the low rates down to about 50 percent on the tail. Expo is an individual taste but a lot of folks like to use as much as 40-50% expo on the high rates. I know some XFC pilots that use up to 80% on their giant scales!
