SU DO KHOI tank
My Feedback: (12)
SU DO KHOI tank
Has anyone mounted the fuel tank on the outside of the fuse? If so where? How was the throttle response?
I had a SU DO KHOI with the tank in the wing and it was fine but, I ran out of fuel in hover too many times!!!! It would be nice to have the tank in view so I could always see the fuel level! If anyone has any pics I would love to see them! Post them or email them to me.
[email protected]
[email protected]
My Feedback: (10)
Tank
The fellas around here like to notch out the leading edge of the wing behind the engine during construction and mount it with a couple of dots of clear silicone. It's visible and mounted out of the way. When it's time to remove the tank, a piece of dental floss can be forced between the tank and wing, and it breaks the silicone seal. Hope this helps.
John W.
John W.
My Feedback: (45)
TN
SU DO KHOI tank
I'm going to mount my oposite my engine like I did my other fun flys... I just can't decide whether to do it with string trimmer line or rubber bands.....
Rubber Bands:
String Trimmer Line:
Rubber Bands:
My Feedback: (45)
TN
SU DO KHOI tank
Hmmmm...... I see the problem now...... I went to mount my tank last night and the nose of the SuDoKhoi is much taller than my other fun flys..... If I rubber band it or use tie raps or string trimmer line, I'll still have to run the lines over the top of the fuse... Might cause fuel draw problems... Unless I mount the tank on the engine side, which I don't want to do... I like having the tank on the side oposite the engine for counterbalance.
I could run the fuel line in a small space between the front of the engine and the fuselage engine bearers... It doesn't bind or pinch.... Idea's??
SU DO KHOI tank
Paul,
I had a Morris Fun Design and the tank was mounted outside, opposite the engine. To run the fuel lines I just drilled a hole in the fuse and put the line through the hole. I dropped some thin CA in the hole to fuel prood it.
Heres a pic of my Fun Design. You kind kinda see the fuel line in this pic. Also, I sent you a Private Message.
SU DO KHOI tank
Paul,
I attached the tank to the fuse with double sided foam tape.
I also drilled some more holes in the fuse and use tie wraps through the holes and around the tank. It was very secure.
As far as a strength issue......I dont know, it didnt seem to have any less strength up front Matter of fact when it crashed ( hover and no gas dont mix ) the nose was not harmed at all. It just broke right behind the wing on the fuse. Typical for Profiles.
Banned
Fuel Tank
My engine may be a little more forward than yours, but I used brass tubing and slipped the line between the engine and firewall.
The area just behind the doublers are waiting for the crash...This area is very easy to break. I do not know if drilling would be wise in this area
I wish they had doubled the entire fuse...... At least then I could have put a bigger powerhouse on it and not worried about thie fuse breaking...
I Also found a weak spot in the elevator..
Flutter is this a/c's worst enemy...I observed my buddy totaly destroy his in the air.
I knotched out the rudder a small amount and ran a strip of ply about 3 inches along the bottom of leading edge to help both sides of the elevator remain stable.
This is a fun airplane....It is fun because it is lite and the wing area..
Good Luck,
Watch your speed.
5
Good Luck,
Watch your speed.
5
