Go Back  RCU Forums > RC Airplanes > Profile and Fun Flying Planes
Reload this Page >
OMP 64" Yak 54 Windex Method
Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
Old 11-26-2005, 11:42 PM
rchighflyer
Default OMP 64" Yak 54 Windex Method
My first attempt with the Windex method discussed in this forum. I hope the graphics will stay on for more than a few flights. Not that hard to do but is becoming very time consuming. Ideas are Termagators I just used his ideas and followed his instructions.
I sure hope that it will be a Whoop-T-Fly.
ID:	360774   Click image for larger version
Old 11-27-2005, 02:09 PM
scolpit
scolpit's Avatar
Default RE: OMP 64" Yak 54 Windex Method
WOW... how do you guys make this graphics? Is this a pre-made covering? OR is all homemade? Where can i buy this "chess table" covering?
Old 11-27-2005, 11:43 PM
rclement
rclement's Avatar
Scolpit, are you talking about the checkboard covering? I got some that is made by Ultracoat. The squares are about 3 inches square and show up nicely from a distance.
Old 11-28-2005, 06:54 AM
scolpit
scolpit's Avatar
Ok, i found the checkboard covering on towerhobbies. I said "chess table" because i had no idea how to say it in english.
Still don't know how to make this "splash" stuff, and the "bubble" stuff comming from the front of the wing. Tks
Old 11-28-2005, 10:05 AM
AFSalmon
AFSalmon's Avatar
Very Very nice indeed!
Old 11-28-2005, 11:40 PM
rchighflyer
Cover the wings in white first, make a pattern on plain paper, transfer pattern to monokote, and then use windex method to fasten to the white. Not that hard.
If you do a search for windex method you will find tons of information. I have found that windex does not stick the graphic to the monokote permanently you have to use trim solvent, not too much or the graphic will bleed.
The splash was done the same way as the checkerboard.
Here is a link for the checkerboard.
[link]http://www.rcuniverse.com/forum/m_712709/mpage_1/key_checkerboard/tm.htm[/link]
Old 11-29-2005, 01:59 AM
P3RIPPERFW
are you putting the trim solvent on your base color then spraying the windex down then placing your graphic?
Old 11-29-2005, 06:45 AM
rchighflyer
Cut your graphic, spray windex on the area where you would like to place the graphic. After place the graphic use a piece of quarter inch balsa to squeegee the air bubbles out. The windex will allow you to move the graphic around and position it exactly where you want it. Allow it to dry overnight. I then used a monokote iron on low heat around 200 degrees (to high a heat will cause bubbles) to help seal edges. Take a cotton ball or q-tip and put a very small amount of trim solvent (to much and graphic will bleed) and go around the edges. Play with this a scrap piece of balsa and find out what works for you.
Old 11-29-2005, 12:52 PM
tetherite
Clear nail polish also makes a good edge seal. Just a thin coat on each side of the edge. Will "disappear" when dry.
FYI.
Ray
Old 11-29-2005, 03:59 PM
tmproff
tmproff's Avatar
To keep graphics on my plane, I just bought a can of clearcoat and spray it on. Works great.
Old 11-29-2005, 10:40 PM
P3RIPPERFW
cool thanks all good ideas, im getting an itching now to put some graphics on my bad boy.......
Old 12-04-2005, 10:44 PM
scolpit
scolpit's Avatar
ORIGINAL: tmproff
Where did you buy it? Does Towerhobbies sell it?
Old 12-05-2005, 09:45 AM
tmproff
tmproff's Avatar
This is what I use:
http://www2.towerhobbies.com/cgi-bin...&I=LXCZW5&P=ML
Old 12-06-2005, 11:30 PM
scolpit
scolpit's Avatar
Ok, sorry to ask again, but my english is not the best. So... What does this spray protects? Ive read the the specifications of the spray, but still dont understand...
Does it protect the spray painting? OR, can this spray protects graphics like checkboard?
Flying checkboard looks really nice, but im afraid of doing it, because, with glow stuff, cleaning, etc, graphics will come out easy.
Old 12-07-2005, 09:46 AM
tmproff
tmproff's Avatar
Its ok scolpit,
I use this paint to protect graphics AFTER I put them on the plane. The paint protects the edges of the graphics from pulling up.
Old 12-07-2005, 11:22 AM
scolpit
scolpit's Avatar
That's what i want Thanks
