Tunnel Vision wing retention?
I have just received my Chip Hyde Tunnel Vision and i have to say i'm very impressed with the overall quality.
After a good read of the assembly manual it all seems very straightforward, but the only thing i am slightly unsure of is are the wing panels supposed to just slide onto the tube joiner and locating peg as nowhere in the manual is any mention of the wings being pyhsically attached to stop the panels possibly sliding along the tube joiner in flight.
Would appreciate any comments/suggestions
Best Regards
Brian
Best Regards
Brian
My Feedback: (9)
IN
RE: Tunnel Vision wing retention?
Chips website says something about taping them on but I think I'd pass on that idea. A friend put in a ply plate and a blind nut in the wing panel. He put another ply plate on the inside of the wing stub. He positioned it so he could reach inside the access hatch and screw it together. I'm thinking he used a thumb screw on the wing panels and a spring loaded hatch latch so he didn't have to use any tools.
Matt
Matt
ORIGINAL: basmntdweller
Matt
Matt
Only takes a few minutes to assemble and requires no tools.
Brian, What setup are you planning to use? I'm running an OS 160 on a pipe, Pulls pretty good on a 13lb plane.
You are going to love this plane, Flies like a dream.
Here's a pic from the maiden.
Hi Dave
Thanks for the tip re using small servo arms to retain the hatches.
I'm also going to use a OS160 which i have just received. Going to start off initially with the standard muffler and a APC 18x6w prop and take it from there, although i'm already thinking about a Just-Engines 160 size purple pipe setup!
Should be a lot of fun, can't wait!
Best regards
Brian
Best regards
Brian
My Feedback: (17)
My TV had a hard wood point that was already installed in the wing. I drilled a pilot hole through it with the wing tube installed, then I put a screw in it. I did the same on the other wing. I leave the wing tube in one wing. it only takes a few seconds to install the wings and the one screw. Check your wings to see if they have a hard point installed already. Look at the wing tube slot, you should see a square indention covered with monokote. That is the hard mount I used.
