one last Uproar 40 question
My Feedback: (47)
MA
I test flew my Uproar 40 today and what a nice flying plane with just a 40 FP.Last question has to do with flaperons.When I deployed the flaps,the nose of the plane pitched down instead of up.Why did that happen?She slows down nice and slow,I'm turning off the flaperons.
I'm not sure what is happening when you deploy the flaps but I think most people, (I may be wrong), only use elev-flap mixing on funfly type planes. This will give you super tight loops. Flaps help lower landing speed and your Uproar should allready land at waking pace. Have you tried the elev-flap mixing?
Good luck.
Ken
Good luck.
Ken
OH
You might have too much flap deflection. These are big ailerons on a light plane. Too much flap will cause drag and they can also act as big elevons causing the plane to dive. I have mine on a c-mix where I get flaps with up elevator and spoilers with down elevator..it's a hoot. But use just a little deflection on the flaps. Also, try spoilers instead of flaps. With spoilers you can use a little more deflection. They can cause the plane to pitch up slightly, again acting as elevons, but you can do awesome slow flight and harriers with them set like this. I flew mine the other day with no wind, and with the spoilerons on, it's forward speed had to be about 5 mph. Took forever to get from one side of the field to the other
My Feedback: (47)
MA
your right Atom.I guess I do have too much flap.I'm useing the JR 421 and the only thing I can do is reduce the deflection.There is no flap - elevator mixing either.As for spoilerons,I don't think there is a way to reverse the flaps to spoliers.The only reverseing on that radio are the 4 basic.
OH
Hmmm..not familiar with JR radios.
I'm using an RD6000 with mine.
Does the Jr have a value for flap deflection, or is it like an end point adjustment pot ? I ask because if it were a value you could go negative instead of positive to get spoilers. Seems like there'd be some way to reverse the flap function to make spoilers. Anyway, my flaps only deflect down maybe a quarter inch.....doesn't take much at all. Watch using flaps and getting low and slow..you can tip stall pretty easy if you're not careful.
flaps
People don't realize that when you deploy flaps on an aircraft, you increase drag. To compensate for flaps you must increase the engine RPM to move more air over the wing to compensate for the increased dragged. Ever notice on a commercial aircraft that when they deploy flaps, the cord of the wing is increased as well? That is to compensate for the extra drag. The increased wing cord decreases the wing loading. Think about it!
Kevin
Kevin
My Feedback: (47)
MA
the JR's adjustments are all done in neg and pos percents.I looked in the users guide and only mentioned on function on the flaps for adjustment.Nothing was said about reversing.And I measured the flap deflection too.1 1/2".So I guess a little reduction is in order.
OH
Ok...say you have plus 50% on your flaps then.. You should be able to make that minus 50% to get spoilers..see what I mean ? Positive numbers make them droop, and negative numbers might make them reflex, like spoilers. With some radios it might be the other way around though: positive, spoilers; negative: flaps. That's how I do spoilers on my RD6000. Might be worth a try.
Re: one last Uproar 40 question
Just an FYI, as long as you have the engine idling as low as possible without risking deadstick, and have the CG a bit aft of where it says on the plans, you can fly the Uproar as slow as you'd like. It just won't stall, even without flaperons.
OH
I've never used flaps for landing...I agree it will land ultra slow as is. The flaps are really a good function for aerobatics. They help with flatspins, super tight loops and flying square loops.
You can do really nice harrier flight with spoilerons as well....talk about slow. I think with spoilers a skilled pilot could land on a picnic table no problem.
