BadBoy V2 reciever tray Need a pic
SC
RE: BadBoy V2 reciever tray Need a pic
what i did and it worked great was i put my receiver in one of the wing halfs. i made about 6" leads to contect to the receiver for the rudder, elevator, throttle and the other ailron. i put the battery in the other wing half to balance and it worked out great. i know some people leave their together, but i don;t have that option. when i put the plane together i slide the half with the receiver up and conected the elevator, rudder and throttle, i then ran the leads for the other ailron and battery thru the middle cut out. i then slide the other wing half up and contected the battery and the ailron and then bolted it up. it worked very well and a buddy of mine saq how i did mine and did his the same. it's just you have to buy 5 leads about 6" long. remember you have to use one for the battery also to get from one half to the other. and don;t worry about having all the leads, cause i used a nimh 1000mah 4 cell pack and got over 5 flights every weekend!!!!
mike
mike
My Feedback: (13)
OH
what i did was to cut a small piece of ply to match RX and glue it in the slot where your battery is suppose to go and put the battery in the wing to where ever needed to get CG rite, that way your RX stays in the fuse. and is easy to get to
TN
I used extensions like MadMikey, but wrapped the Rx in foam and put it inside the wing, as far back as I could get it. Pretty solid, light, and vibration shouldn't be a problem. I decided I wouldn't waste time with the velcro/balsa tray/etc.
The manual does need better pics, doesn't it?
NY
Hey all,
We have announced the new name on the rename Carolina 3D threads.
Go here
http://www.rcuniverse.com/forum/m_37..._4/key_/tm.htm
http://www.rcuniverse.com/forum/m_3832308/tm.htm
Go here
