I wanna get myself a profile
GA
I'm interested in getting myself a .40 sized profile. Looks like my choices are between the any OMP profiles and the MOJO. My first concern is what engine has good 3D performance without paying too much money. It would be nice of yall to post your plane and plane setup so i can get an idea of what to get. Thanks
RE: I wanna get myself a profile
My Feedback: (14)
If you are on a budget, get a TT 46 Pro and standard servos. Both will work fine on the planes you listed. The Mojo comes out LIGHT, so the TT is plenty of power. Mine was 3lbs 12oz with the TT and Futaba 3004s with a micro servo for throttle.
My Feedback: (9)
OH
Joebob nailed the setup. The TT 46 is one heck of a engine and standard servos will work with any of the 40 size profile.
If you are new to profiles and or 3D flying, OMP's Edge would be a perfect choice, if you have some stick time under your belt I would go with the Yak.
ORIGINAL: coveredup
dont mess around bro. [link=http://www.swanyshouse.com]mojo[/link]
Saludos.
ID
This is a Morris the knife with a 52 Magnum ,as a rule I dont get into ARF's but I got this one off ebay for 42.50 shipped brand new in box,thats way less than the kit.Anyway it hasnt seen the air yet but I have seen others just like it and it will do about anything a person could want.It has pull /pull on both the rudder and elevators.as soon as the weather permits we'll see what its got.
Tons of threads on engines but the best bang for the buck is the TT Pro .46 or GMS .47. I have run many of these hard and they perform every bit as good as the OS .46.
GA
what about the Magnum 52? Its just a little more expensive than the TT on tower hobbies. are magnum engines any good? About how long does it take to build a mojo? I'm a freshman in highschool and have little time building except on the weekends.
GA
Do u have a link to where i can find directions to bomber field? I might come, i can only come on sunday though as i have a state championship for gymnastics on saterday.
My Feedback: (10)
ORIGINAL: Gymnast
JW
IA
the mojo kit is easy to build, I built my 1st kit this winter and the plane rocks.....mine wieghs 3lbs 14os, at least a half a lb lighter than any other profile i own in the 40 sized class
IN
ORIGINAL: John Wells
Hey Chris, I've seen several of the Magnums, and IMO they don't transition well for 3D. They run good on top end, but that's not what you want for 3D. The TT 46 is waaaay better than the Magnum 52. An engine that has a lousy mid-range will delay and frustrate your attempts to learn 3D.
JW
ORIGINAL: Gymnast
JW
However , one must spend a little time massaging out the good in a mag..52 .
Fist , seal the carb to the engine.
then, drill out the muffler outlet 1 or 2 drillbit sizes bigger than the stock opening.
Put a larger pressure nipple for better fuel delivery.
I know , Why spend that much time?
To make it a short story. Mine throws a 13*4 APC wide with authority, and the 12.25*3.75 wide is nuts on punch out with this combo.
Plus , Are you on a budget? Most of us are.
GA
Whats a better alternative servo i can get that has better performance than the S3004 yet is still pretty cheap? I have some really old HS-300's from a plane i got for free but can't find any info on it.
GA
Ok i think im going with the mojo now. I have heard too many good things about it. Is there any special building tools i need to finish the kit?
AK
Check out the "MOJO for dummies" thread on the profile brotherhood.com website. There you will find a step by step description of how to build a MOJO.
[link=http://www.the******************.com/forum/viewtopic.php?t=4578&start=0]HERE IT IS[/link]
