Go Back  RCU Forums > RC Airplanes > Profile and Fun Flying Planes
Profile plane settings >
Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
Old 12-31-2002 | 04:36 AM
Default Profile plane settings
Hi guys!
Soon i'm going to be building a Lanier pro twister. I would like to get some info on what kindda settings, mixing use on your radio gear and whar kindda hardware you like using on your profile. For example what would be a good size/pitch propeller for this plane. i'm planing on using a OS .46FX and the main thing i wanna learn with this plane is hovering. What kind of setting you guys use on your radio to hover if any special ones?? I'm thinking bout using a futaba 6XAPS. Will this be a good matching radio for this plane? Just give any tips you might think will help a newbie profile pilot to set this like a pro! Sorry for asking so many questions guys but people at the field can be real a**es sometimes when you try to get some questions answered.
Seems that doesn't happen so much in here i guess. Well anyway any guys form the profile brotherhood or anybody else want to share tips!??
Dan
Old 12-31-2002 | 04:41 AM
I fly my profiles with a T6XAS and its a good radio for it.
I am able to get spoileron mixing and flapperon mixing out if it.
You kinda Have to trick the radio a bit but you can do it.
For throws your gonna want to be able to get a lot. Use the dual rates and Expo to tame them down till you get used to the plane.
Then when you are ready, you can go back to higher setting for throws.
Old 12-31-2002 | 04:45 AM
No special hardware needed. I used 2-56 30" rods for the ele & rud. nylon clevis's any standard servos will work. On the prop I try a few APC11X4,11X5, 11.5X4 maybe a 12.25x3.75 too.
I did splurge a little on hardware, I put Sullivan tail wheels on them....Gator
Old 12-31-2002 | 04:48 AM
Man! Controllers make all the money.........
Old 12-31-2002 | 05:17 AM
What is a good mix for harrier hovering if any is used? Flaperon/elavator? Spoileron/elevator? That is kind of my main interest for this plane any tips on how to start hovering as for practice goes send them too!
Old 12-31-2002 | 05:25 AM
Try to hover without any mix on at first. I think it'll be easier to learn that way.
Enter the hover with little or no power. Dive the plane then pull it up with low power. As the plane comes to a stop in the vertical position try to catch it there with power. You'll figure out fast just how much to add. Then use rudder and elevator to keep the tail under the nose. Its kinda like balancing a broomstick on you hand.
If there is any wind, enter the hover while flying downwind. this will help keep the wings steady as its hovering. The wind will be on top of the wings pushing the plane belly first....
It takes a lot of time and practice but you'll get it eventually.
Old 12-31-2002 | 09:37 PM
Hey
What about the CG of the plane?? I'm thinking that if is a bit tail heavy it will hover easier?? How far back can i move the CG back with out loosing a lot of the normal attitude of the plane?
Old 12-31-2002 | 09:46 PM
go to the back of the CG range shown on the planes and if the tail still drops: "BINGO", your there. I fly most of my FF type planes with flaperons....Happy New year....G
Old 01-02-2003 | 09:22 PM
Hey!
I received my PT today i already started construction..I'll post pics as soon it's finished. Thanks for all the info guys i'm sure gonna huild arround those tips! HAPPY NEW YEAR EVERYONE!!
Old 01-04-2003 | 01:28 AM
Default Scary building!
Ok
I already built the fuselage but that wing starting to look scary to build guys!
Old 01-04-2003 | 01:56 AM
Hey Danny whats up! is "Sentella" in the house.
Old 01-04-2003 | 02:21 AM
Default Hey man!
Hey wassup man! see that you found me here huh!
Old 01-04-2003 | 03:33 AM
Tell me whats the scary
part about building the wing that you are talking about?
Old 01-04-2003 | 04:25 AM
Man ALL OF IT! it's just to many parts for my experience everything else seems basic i just don't wanna screw this up.. Maybe i'll bring the plan over to the field on sunday so you can see what i mean..it'll probably look easy for ya though
