Go Back  RCU Forums > RC Airplanes > Profile and Fun Flying Planes
How Do U Do A Blender? >
Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
Old 01-12-2003 | 03:15 PM
Default How Do U Do A Blender?
hello i was at a local scale flyin and my friend was doing blenders and man do they look cool so if you could help me that would be great!
Old 01-12-2003 | 07:20 PM
http://horizon.hobbyshopnow.com/articles/1022.asp?pg=5
He makes it sound to easy.
Old 01-12-2003 | 08:14 PM
Start way up high. Push the nose straight down. Roll left 2 to 3 times. Now all together, give 3D rate down elevator (45 degrees), full right rudder, and full power. After like one second (maybe 2) chop the throttle to just above idle. The plane will have done a few extremely violent snaps followed by a slow flat spin. Use throttle to control the flatness of the spin. Don't look at it too long, Earth is on her way. DO NOT FORGET TO RETURN TO LOW RATES AFTER THE SPIN. PULLING OUT WITH A 3D RATE CAN EAT THE PLANE.
Old 01-12-2003 | 11:43 PM
if you are using a magic, upright spins are easier to do. get some altitude, start a spiral spin to the left or right (i usually go left) left rudder,left aileron , full up elevator, half throtle or less. After a spin or two flaten out the wings with neuteral or a little right aileron (still holding up elevator and full left rudder) the plane will break into a tight flat spin. to exit just release the sticks.
if it still is spiralling nose down you may be too nose heavy or you don't have enough elevator to lower the tail. beware of too tail heavy, it can make exiting the spin harder.
if it tumbles rather than spins you are using too much elevator.
Once you are in a flat spin adding more throttle will make it spin faster and slow the decent
