flaperon & the knife
i'm running morris the knife and futaba 6xas with each ailerons connected to a different channel
i have just seen in the manual something about flaperon mixing
"Flaparon Mixing 50% 50%"
what does it mean ?
thanks
what does it mean ?
thanks
goog question...I'll follow this thread to find out what 50%-50% means......go ahead and program the flaperons and take some % away and add some in and watch what happens....Swany will robably know the answer to this one...G
My Feedback: (45)
TN
I believe the "Flapperon Mixing 50% 50%" refers to mixing elevator with ailerons and the the two numbers represent what percent of travel in either direction. So if you wanted up flaps with down elevator and down flaps with down elevator, you'd use 50%, 50%.
If you wanted up flaps with up elevator and up flaps with down elevator, you'd use -50%, 50%.
If you wanted down flaps with down elevator and down flaps with up elevator, you'd use 50%, -50%.
Does that make sense?
