Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
Prop Help Please
Old 04-07-2003 | 01:53 AM
garydog's Avatar
Default Prop Help Please
I made a pqhor with an fp 40. Tried a 11x4 I had laying around. Worked ok but I think A little smaller prop wold help. he 11 would barely hover and would not pull out. My rpms were low. 9x4 or 10x4 Maybe I will buy both. These sure are super fun to fly.
Thanks Dan
Old 04-07-2003 | 03:43 AM
Dream_Flyer's Avatar
My Feedback: (7)
Default Props :o)
I think a 10-4 would be the way to go. I have one on a O.S. 32sx and really does a good job. APC
Old 04-07-2003 | 03:46 AM
PaulSwany's Avatar
My Feedback: (45)
I think the 10 x 4 would be perfect... I like the 10 x 4 MAS 'cause it's soo durable!!
Old 04-07-2003 | 03:50 AM
My Feedback: (7)
Default Oh no :o)
Is my thinking going along with someone elses. I must have had a brain burst . 14-4 apc yeah yeah thats it 14-4 lol
Just kidding the 10-4 apc or as Paul said MA prop would work great. I just do not have available the MA prop here just APC.
Old 04-07-2003 | 09:13 PM
Try an APC 11x3
Old 04-08-2003 | 01:47 AM
any suggestions for satio 56 on pqhor? currently i'm using 11/4 apc...works fairly well but i'm new to 4 strokes...thanks guys
Old 04-08-2003 | 12:46 PM
Stay away from an APC on a bushed motor, which a FP is bushed. The APC does not flex will a woodie or MA and the FP won't perform worth a hoot (typically). I'd go with a MA or preferably a woodie. Considering that it is a QHOR, I would think that you would lean towards a MA considering that it is forgiving when it strikes the ground, and it flattens out with RPM so it won't make the plane fast. A 11X4 MA should work nicely unless you are flying at a high altitude. I'm running the 10X4 MA on a TT36 w/ MCM and am thinking of going to a 11X4 MA and taper the tips on my PQHOR.
Hacker - I can't help you regarding the 4C. Those little ones and me don't seem to get along, so I go rid of them. (Maybe a 12x4 MA?)
Kevin
Old 04-08-2003 | 12:55 PM
johan_torssell's Avatar
Default Saito 56
11/4 is a to small prop, it will most certainly over rev the engine.
I use a 12x6 Master Airscrew and get 10300 rpm on ground wich will be something like 11000 in air.
The engine has a max recommended rpm of 12000.
Old 04-08-2003 | 01:51 PM
garydog's Avatar
Default 4000 Ft
I am at 4000ft And I have found that a 9x4 has worked the best. For what I want slow and low. The 10 just never found the power band. I think If I was lower the 10x4 ma would be the best. Now I am wishing I would have put a 46 on it. I have craseh it 5 times in 2 days. No damage. I have never even come close to crashing my topcap. THese things are a gas. Thanks again. Dan
Old 04-08-2003 | 02:10 PM
Its hard to beat these SPADs! If you dork it - typically you just check the prop & batteries, fill it up again, and go! I did break the engine mount on my PQHOR Sunday, but I cut mine way down to cut out some weight, and I 'dumb-thumbed' it doing tail touches in 25 MPH gusts I would never dare to do that with one of my balsa Fun-Flys! The SPADs don't fly as good, but you can't beat the durability! It develops the "NO FEAR!" flying technique!
Kevin
Old 04-08-2003 | 06:03 PM
johan_torssell,
thanks, will try the 12/6...luckily i don't use full throttle on my pqhor
